Psr- 500
felicia
WACO
dose anyone know how many CONV-ch you can put in a scan list
felicia
WACO
timjude said:
36,000 or so
wow, thanks so in scan list 1 i can pgm 85 conv-ch and also pgm tgrp ch whit out haveing to go in to scan list 2.
36,000 is the total capasity of the scanner with all v-folders included. total of 1 scan list in 1 folder is much less than that. probably just under 200 or so.
36,000 is the total capacity of the scanner with all v-folders included. total of 1 scan list in 1 folder is much less than that. probably just under 200 or so. (bad spelling is reason for edit)
DonS
Franktown, CO
The scanner's "main memory" can hold 1,852 objects. Those "objects" are Conventional channels, Talkgroups, Trunking systems, and Search/Sweeper settings. (CONV and TGRP each take one "object space", the other types take more).
Any object can belong to zero, one, two, ..., 21, 22 scan lists, without impacting memory usage. So, a Scan List can "hold" 1,852 conventional channels (if that's all you had in the radio), 1,842 TGRPs for a single P25 TSYS, 1,000 Conventional channels plus 842 TGRPs for a single P25 TSYS, etc.
mikey60
Oakland County Michigan
If you don't do anything else, 1852 conventional Objects.
If you add trunked systems, then that number will go down accordingly.
Mike
