PSR-600 audio has a hiss
#1
okey so everyone talks so good about this PSR-600
but why does it sounds like crap? i use the scanner for System Type P25 only
i have a friend that owns a Uniden Bearcat BCD996T and side by side hands down puts the PSR-600 in the water!
Also when a talk group becomes active VC appears with no audio often--- then Dg appears and Audio is clear... it does this 50% of the time
