fmulder13
Hi all,
At the moment my PSR-600 is set up to scan two lists, each containing primary dispatch and a couple special car-car channels for one agency each, each agency tied to the same site of a statewide multi-site Motorola analog system. (It's the Oklahoma DPS system, Norman site, and I'm scanning OU PD and Norman PD in their own respective lists.) I'm finding that, while in scan mode, transmissions from Norman PD are being missed. Norman PD's dispatch channel is set as a PRI channel, PRI is enabled, but during scanning I'll either hear only a reply to a question I never heard, or I'll hear one side of a conversation. This phenomenon disappears completely when I put the scanner into MAN mode on Norman PD, or when I have OUPD and Norman PD as my only two favorites. I'm also pretty sure that this never occurs on the OUPD channel, that the scanner will fail to interrupt OUPD for Norman PD while in scan mode, and that this is a new phenomenon since Norman PD recently began using a new talkgroup for their dispatch channel. Any suggestions?
