PSR 600
cpetraglia
Fairfax, VA
Simple question here. Does anyone know if the front panel earphone jack is a stereo or a mono jack?
I have always had problems using a mono plug. No info in the manual to this detail. If no one knows for sure, I guess I will pull the cover and see for myself. Trying to avoid that.
Thanks in advance,
Chuck
signal500
Florida Panhandle
Thanks in advance,
Chuck
It's a stereo jack.
