psr 800 and rebanding
gregg22
monroe,mich
hello
Is there a way to manually change the control channels thru the ez scan soft ware on the mpcs trunked system?
detroit780
Michigan
Update
You can just download the latest library from RR and update. Or if you want you can open up EzScan and go to the trunked tab and highlight the MPSCS system go down to the system and click on the site you want to change and edit it.
Les
hello
gregg22
monroe,mich
Thanks I tried to edit the channels yesterday and it wouldnt let me worked fine to day however.
Gregg
