PSR-800 ! in device manager
bbachman
Spring TX
I have a PSR-800 and when I plug it into the USB port, it appears that a driver is missing,(See attachment 1)I am using the EZScanDGInstall_v1.08.zip from the GRE website and when installing I receive a pop up box that indicates that an inf file cannot be written. (See attachment 2) This is windows 7 x64.
I have done everything listed in the posts regarding this to no avail. And do not have the original cd, and that seems to have fixed the issue for some.
It looks like I need the inf file from the cd.
Any ideas?
Thank you in advance!
Barry
jyams
Memphis, TN
Follow the instructions below for Windows 8 but in Windows 7. Did it myself just last night and now Windows 8.1 sees my PSR-800. Be advised you will need the CD in the original equipment box. That CD has the .inf file that windows needs to load your driver. Grab that file off your CD, save to Desktop, go to device manager, right click on PSR-800 and uninstall the existing driver, then reinstall driver choosing option to browse computer, and browse to that file on your desktop. You might have to disable the digital signature check as in the post below to solve this in the end. And, be sure you are doing all of this as "administrator".
http://forums.radioreference.com/gre-scanners/248386-psr-800-windows-8-a.html#post1857362
bravo14
#850Strong
I have found my cd for the psr800. I found the inf file and put in a zip file I hope this works for you. When you open the folder just copy the file (do not use the inf folder) over to the C:\windows\inf\GRECOM_PSR-800
bbachman
Spring TX
Thanks everyone!
Everyone,
I really appreciate the suggestions and upload of the INF file and I will use the WIN 8 installation method.
Updates to follow :)
Barry Bachman
PSR-800, PRO-18,PSR-600, PRO-164, PRO-97, ST-2 Antenna
bbachman
Spring TX
Issue Resolved!!
Thank all of you for your assistance.
I was able to get it all working by installing the software on another pc and did not get the file warning, and then moved the .inf file over to the other pc, and using the update driver option, was able to direct it to the file, and now everything is up and running.
Barry
PS) bravo14, that was the file I needed thank you for the upload.
bravo14
#850Strong
Barry
No problem glad it worked out for you.
redshift
Eastern WA
Just wanted to post another thanks! I recently updated to Windows 8.1 and my install CD for the PSR-800 is long gone. The file you posted is like gold to someone like me. :D
