PSR700 EZ-Scan question.
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Hammond, IN
I'm pretty sure the answer to this question is "No," but I just want to make sure (and a search was no help).
Can bulk entries (for lack of a better term) be done when using the software? I have a list of about 58 miscellaneous frequencies (as I call them) that I need to put into a scanlist, but I don't want to have to put them in one at a time; that would take me all afternoon.
Thanks in advance for any info you may be able to provide.
SSSG
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I might look for a copy/paste function of some kind....best regards..Mike
TES
America's High Plains
While looking at the "Conventional Frequencies" screen you should see an "Import from:" area—with several options—at the lower-right of the screen.
NWI_Scanner_Guy
Hammond, IN
Tried that, and had no success.
I'll give that a try when I get home (got one more hour of work to go).
NWI_Scanner_Guy
Hammond, IN
I can't seem to find a "conventional frequencies" screen on this program.
scannerfreak
Well Known Member
Indiana
Up top under advanced, make sure you have the "show conventional" and "show trunked" entries checked.
NWI_Scanner_Guy
Hammond, IN
Start the program and look at the bottom of the screen.
As you can see, there's nothing about conventional frequencies at the bottom.
Obviously I'm missing something and am still stumped.
NWI_Scanner_Guy
Hammond, IN
D'Oh!! Okay, now I've got it.
I'll try some importing and see how it goes.
Thanks to everyone who replied. I appreciate the help.
NWI_Scanner_Guy
Hammond, IN
Okay, it imported the frequencies okay, but it didn't import the alpha tags. Just showed "New Channel" for each freq. I'll keep working at it until I get it right.
Thanks again for all the assistance.
scannerfreak
Well Known Member
Indiana
When importing, make sure you are assigning the columns up top to match the appropriate info you want to import.
The info needs to be formatted correctly in order for all the columns to show up, so make sure you have the info tab delimited.
NWI_Scanner_Guy
Hammond, IN
Alright!! That did the trick.
Thank you for all your help scannerfreak...I really appreciate it.
