PSR800 and PDW/discriminator
ocguard
PA/MD
I have been using my PSR800 to interface with PDW for POCSAG tracking via the sound card and earphone jack, however, I'm wondering if the built-in discriminator tap will allow me to use the PC/IF out either through the USB or earphone IF out. Can this be done?
DaveNF2G
Rensselaer, NY
Unless something has changed, GRE's PC/IF only provides access for programming and remote control of the scanner, and P25 CC data (user selectable) for use with PRO96COM software. There is no baseband audio available there.
ocguard
PA/MD
Thanks, Dave. I played around with it quite a bit and had no luck. Will still with the soundcard.
