PSR800 issues when losing power
SShuster221
Live Audio Admininstrator
Ocean City, MD
All,
I am trying to experiment with a new PSR-800, Seems when the power supply is removed from the scanner the unit then goes into some kind of programing mode and must be hard restarted. Does anyone know if there is a way to make the unit return to power on mode, if in fact it does loss power?
Thanks,
Scott
