PSREdit500 can't import
burchill
halifax
First new to scanning, and am playing around with my gre psr 500 and and software psredit500 and in the trunk systems i am trying to import talk group and i have selected them but the import system button is not enabled for me to import?? do I need a licence to get full acess?
mikey60
Oakland County Michigan
You need to make sure you select at least one site if the system has multiple transmitter sites. Once you've selected a transmitter site, the button will be enabled.
Mike
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Mike
I just ran into this issue, yesterday.
In my situation, I was just wanting to add some TGs to one of my scan lists. I did not want to make a new TSYS entry, which the software was wanting to do.
Is there a way an option could be added, to append TG(s) to an existing TSYS or scanlist?
rwier
Phoenix, AZ
Don't know if you have the same software or radio as the OP, but if so, Trunking Objects tab.....select the Trunking System you want to add to.......Right click in main grid.....select Add Talkgroup...
If this was not relevant to the question/thread please ignore.
mikey60
Not currently, but I'm looking into it...
What I've done on many cases, is to import the talkgroups I want into a new TSYS, then switch to the Trunking tab, select all the talkgroups, and then move them into the existing TSYS. Long way around, but it works.
Mike
krokus
Mike
I ended up adding the TGRPs with the "new" TSYS, copying the wanted items to the clipboard, then deleting the "new" TSYS, and pasting the items into the existing TSYS.
