PTT ID MDC1200
jonnychaos
Hello all. My company has put me in charge of maintaining our fleet of radios. I am fairly new to the 2way radio world, so please bear that in mind. A current issue I am having is with PTT ID. We have a mix of vertex standard and Motorola radios, primarily the VX-2100s and the CM200s, but also have a couple of other models (XPR-4350, CM300, and a couple Kenwoo radios). The vertex standard radio IDs display on our ID board and the Motorola IDs will display on a CM300 radio but not on the ID board in the office. I believe they both use the MDC-1200 DTMF protocol for PTT ID. Any suggestions on what I should be looking for in the Motorola CM200 programming to get their IDS to display on the ID Board. The previous person setup the office base stations using a mix of Vertex Standard VX-2200 and Motorola XPR-4350. I have 4 yards that each have their own simple base stations. Any guidance would be appreciated.
jonnychaos
What is the make/model of the ID board?
I have been doing further research and I believe the issue is that the Midian ADD100 will only decode and display DTMF and not MDC1200. Does anybody know if the Motorola CM200 can be set to use DTMF instead of MDC1200?
IFRIED91
Arrive alive
NYC area
Vertex standard formally used the Cimmarron VME/VDME-100/200 respectively (one had encode only the other had both encode/decode MDC1200 and GE Star!!!! YES GE Star decode on a portable) from what I know the newer digital vertex radios (both the p25 and DMR line) had MDC1200 functionality built in
kf8yk
You could change the DTMF only Midian ADD-100 decoder to a Midian ADD-MF which supports DTMF, MDC1200, G-Star, Fleetsync and 5 tone ANI formats.
jonnychaos
Yes, after further research that is what I'm doing. Thank you.
