Public Safety Answering Points (PSAP) in Ontario question
hotpocket
I’m sure this could probably go in a totally different section, but I’m curious specifically about the PSAPS in Ontario. When you call 911 from a mobile device, are the dispatchers able to remotely activate your phones GPS to allow them to get a better location while you are connected to them? The reason I ask this is a couple of years ago, my mom and I were up near Orilia doing some fishing. We noticed there was some individuals who had started a fire directly below a wooden structured bridge. Concerned the flames were getting far too close to the bridge, we called 911. Unfortunately, we were unfamiliar with the area, so we could give a general location, but not the street where the bridge was on.
Because I’m security conscious, I generally don’t have my location active on my Android phone. I noticed when I was on the call with the dispatcher, the location icon appeared on my phone. At the time I just assumed they were able to remotely activate it to be able to better identify where I was calling from. I’m just curious, is that actually possible? In a situation like that, I could actually see that capability being extremely helpful.
On a side note regarding the incident, it was actually kind of interesting. The Rama Township fire department responded with lights, but no sirens. When they arrived, they drove on the bridge very slowly. When they exited their vehicle, the actually approached from both directions on the bridge on the one side, so they were flanking the people who started the bonfire. You could definitely see that they did not want to give the people the heads up. Almost like they’ve had very similar calls before.
Forts
Ontario, Canada
It still isn’t super accurate however, which is why you always hear police dispatching calls for ’a dropped 911 call in the area of….’ which might have an uncertainty of a couple KMs. It’s also why you see groups like the OPP advocating the use of apps like What3Words etc.
But at its most basic, they at least have a general idea where you are.
Noseybody
Eastern Ontario Canada
It still isn’t super accurate however, which is why you always hear police dispatching calls for ’a dropped 911 call in the area of….’ which might have an uncertainty of a couple KMs. It’s also why you see groups like the OPP advocating the use of apps like What3Words etc. But at its most basic, they at least have a general idea where you are.
I believe it depends on the accuracy of the phones GPS. The same GPS that gives info to What 3 words would affect the accuracy of any app using it.
hotpocket
I definitely appreciate the replies. I had a feeling that was the case, but it's cool to have confirmation
exkalibur
York, Ontario
Well, it doesn't seem that accuracy gets passed along to the call takers around here...
My guess is that the user keeps the GPS turned off on the phone, so when they call 911 their phone has to get an updated almanac and get their location. Depending on the last time the GPS receiver was used, that might take awhile so it sends an approximated location.
sirsmiley
Ontario
The cell tower you're associated with gets sent as the default address until GPS kicks in. This is why if you hang up right away there's no GPS fix unless you already had GPS on. Also, 911 calls will failover to circuit switched if required and your phone will put out higher than normally allowed wattage
