Push Clock Setting Or GPS Location To Scanner Via LAN/USB Remote Command?
jonwienke
More Info Coming Soon!
VA
@UPMan @UnidenSupport @ProScan
Does anyone know if it is possible to set the scanner clock, or send a GPS location to the scanner via a remote control command through LAN/USB serial control? Or are those functions only supported through the dedicated GPS serial connector?
Asking because it would simplify setup if I could put a GPS in my Raspberry Pi remote head project, and push the time and location data to all connected scanners periodically.
boy7777777777
Arkansas
I know the scan droid x36 program supports gps push from the program to the scanner. I can use teamviewer to access it remotely. Not sure if that’s exactly what your asking about.
ProScan
Software Provider
Ontario, Calif.
Check out the DTM protocol command on setting the scanner clock
{edit} Also the LCR Get/Set Location and range in the same document.
