Q:does marcs IP have same zones as OLD marcs?
#1
i am getting ready to program this into my scanner.
i have a GRE psr500 so i have to break down regions across multiple v-folders -else there isnt enough memory in one v-folder for everything (i also have local pd and sheriff)
i program the whole state since i drive the whole state for my job in sales.
so my question:
are there still MCALL and MCOMM zones like on the old system?
someone once gave me a map showing what counties were in each mcall and mcomm areas, as well as which osp districts were in each zone.
wa8pyr
Technischer Guru
Moderator
Ohio
#2
so my question:
The physical zones for the system have changed, but the zones for MCALL and MCOMM have not changed, so your map is still valid.
