Quantar and JPS SNV12
70cutlass442
Has anyone interfaced a Raytheon JPS SNV12 to a Quantar? What is the best method of doing this? I will have 2-3 UHF downlink radios and will need to use the Quantar for local VHF RX.
Yes. Using 2 wire with a mix of MTR2000's and Quantars for our remote RX radios. 4 wire to the repeaters.
70cutlass442
So I assume you are relying on the SNV12 to do the keying tones (2175Hz)? I had heard that you can do COR but I like the 4 wire idea better. Would either of you happen to have the pin locations on the Quantar for this? I am very new to this station and am getting confused with how many different ways this can be done.
Firebuff880
Boynton Beach, FL
For the ACU family they have always been great with the Technical notes and Cables. I would expect the same for the SNV product line.
Have you checked with them ?
Yeah, we use tone remote for all ours.
You can hook up the 4 wire circuit in two places:
50 pin telco connector
Pin 1 = Line 1 +
Pin 26 = Line 1 -
Pin 2 = Line 2 +
Pin 27 = Line 2 -
Pin 3 = Line 3 +
Pin 28 = Line 3 -
Pin 4 = Line 4 +
Pin 29 = Line 4 -
Or the 8 pin connector on the top right
Pin 1 = Line 1 +
Pin 2 = Line 1 -
Pin 3 = Line 2 +
Pin 4 = Line 2 -
Pin 5 = Line 3 +
Pin 6 = Line 3 -
Pin 7 = Line 4 +
Pin 8 = Line 4 -
There's a jumper that needs to be set for 2 wire vs. 4 wire
JU1010 on the wireline interface board.
The Quantar installation manual covers all this.
70cutlass442
Okay, looking at the RSS now, I see the wireline configuration and the TRC options. I will track down the manual to be sure the jumper is selected properly. I assume I will use pins 1&2 and 4&5 on one of the SVMs (TB1-12) on the voter... Stupid question, does the Quantar generate pilot tones on the RX audio pair so the voter knows there is audio present?
I have a manual here which I think I am getting a good understanding of. I have spoke to them on before and are always very helpful.
Yes, the Quantar generates the tones.
I believe that is the right pins on the SNV-12, but I don't have the manual in front of me.
70cutlass442
I went to the site this weekend and realized that I do not have a wireline card installed in the station. Have you ever done this using COR and PTT instead of EIA tones? Do you see an advantage to one method over the other? I am not opposed to buying a wireline card if need be.
Ah, OK, used to be they came with it, but newer versions didn't.
Ours had them standard.
You could use a remote tone box to handle the transition.
70cutlass442
Thanks for all the replies. Will get this on the bench this weekend and see what we can make happen.
