Quantun QP-2100 CPS/Programming Software
Gmork
Broward County, FL
I own a Quantun QP-2100 (DMR) portable. I typically use it for local repeaters at home & mainly collects dust. I need to do some updating to the codeplug. I no longer have the programming software for it. I need the software that is branded as "CPS QP2100" I need version V1.14 due to the older firmware that is on this radio.
I reached out to Quantun 2 weeks ago & I'm still waiting a response. I am glad this was my starter DMR radio I purchased in 2015...
Gmork
Broward County, FL
The radio is identical to the Connect Systems CS750. I went to the website for Connect Systems & downloaded their CPS. The firmware & bootloader are the same versions for the older version of the CPS I found & it won't read the radio.
ke8bfw
Hi,
Did you have any luck ? I have a buddy with the same issue, Connect Systems software does not see his radio either.
73
Fritz.
