query about programming Motorola MC Micro
Sofia, Bulgaria , KN12QN
#1
Dear colleagues,
I would like to ask for some help and tips for programming Motorola MC Micro radio.
I know that this is a very old radio, however it works very well and I would like to use it for AMPS.
It is in the VHF band 136-174 MHz .
I have the RSS ( micromst) Field Programmer R01.02.01 / 17 Non 1987 , which I use with a very old laptop PC 386 , running DOS 5.20 , and the cable which I connect from RS232 port of PC to the 15 pin main radio unit (when control head is removed from radio) . I start the program from an FDD.
I load the ANSI.SYS file in config.sys, in order the RSS to be visualized properly . I switch off the cash as well.
Reading the radio is OK, although it shows some error message, I can see all the parameters of S-5 signalling system, as well as RX & TX frequencies for each channel.
However, after modification of channel info ( frequencies) , when trying to write to radio, it shows and error message and does not want to write the radio. When using the option to create a codeplug from scratch, I get the same result- an error message and does not want to write to radio...
The radio is EVA-9 model with display, 32 channel, 136-174 MHz sub-band.
I know that I am doing something wrong, but I do not know what exactly :)
If someone of you remember how to deal with these radios, I will appreciate .
Thanks in advance
Bob
LZ1CBK
