Question about antenna and coax
medziatkowicz39
WEIRTON
I purchased an OmniX antenna and 75 feet of SureCall SC 400 coax. Did I make a good decision? I already receive the coax but the antenna won't ship until next week because they are waiting on parts.
KB4MSZ
Billy
Tampa, Florida
I looked around quite a bit for the important specs on this coaxial cable, such as velocity factor or loss per foot at a given frequency. Found nothing. At VHF and especially UHF frequencies 75 feet of coax can have a lot of loss depending on it's quality of construction. You would want to use the minimum length required at these frequencies.
As for the antenna I don't have any knowledge of the OmniX. Someone else likely will.
SureCall makes consumer cellular bi-directional amplifiers. It's unlikely they make their own coax. It's probably a copy of Times Microwave LMR-400. Very likely it's a super-flex variant as those tend to be more popular with consumers trying to do their own installs. I'd expect the specs to be similar but slightly below that of Times Microwave LMR-400UF.
Probably decent stuff and good enough for hobby use. Since installing your own connectors can take special tools that many don't have, there's value in getting pre-terminated coaxial cable like that. You'll be reasonably assured it's been assembled correctly and will work right out of the box.
Just make sure you properly waterproof all your outdoor connections.
majoco
Stirrer
New Zealand
Practice, practice and practice - and the right tools. Don't be scared of it and get the good connectors. Find the installation diagrams with the dimensions and use a bench magnifier to get right down to the details. Don't solder the centre pin - when you've completed the job and it looks good, take it apart, cut the coax down an inch or so and do it again.
I spent a few years terminating rigid solid coax with screw "C" long back connectors that had to be done right the first time to preserve phasing at 330MHz frequencies on airport glidepath installations. The solid copper outer had to be cut and splayed out with a craft knife - couldn't use a pipe cutter as the indentation made an impedance bump.
medziatkowicz39
WEIRTON
Installing Times EZ connectors on LMR cable takes about 1 minute starting from a bare end of coax and the connector in the package and they come out perfect. You just need to have the right tools on hand.
where can you buy these at?
bharvey2
The right tools make all the difference.
Unfortunately the right tools are usually out of the range of most hobby budgets.
Middle of the road crimpers for common hobbyist coax sizes aren't terribly expensive in the scheme of things especially given what some hams spend on a decked out HF system. Would they hold up to the daily activities of a pro installer? Not likely. I have purchased crimpers on Amazon that I use at home and they work fine for the hobbyist application.
On a different but related note. I like the crimpers much better than soldering. Dropping molten solder on my bare foot is exactly the "pain in the ass" mentioned above but it hurts none-the-less.
Yes, absolutely. I have a <$100 set of crimpers and strippers at home that work great.
At work, using LMR series and Heliax, it's a different story, but that's out of the range for most hobbyists.
Hams confuse me. They'll spend several thousand dollars on an HF rig, then $25 on a BaoFeng, then complain about the high cost of tools and connectors.
Ah, memories from my childhood. Same applies for welding. I only welded once while wearing tennis shoes.
bharvey2
/QUOTE]
Ditto with hand held plasma cutters. First time had cloth backed gloves. BAD mistake. Had to go the hospital several times a week for a while to have the burns on my hand debrided while it healed. Glad to scratch THAT off my bucket list.
cwhill
Northeast NY
I like the Omni-X a lot. Well made and works very well for me, in my area with my scanners.
