I recently saw a friend setup 2 Yagi antennas aimed almost 180 degrees apart then hooked to a 2 way power divider with 2 equal lengths of coax. I had heard that this could be done but I'd never seen it in person before, he mentioned that the two coax cables that connect from the antennas to the power divider must be the exact same length which makes sense to avoid phase cancellation.
I would like to do the same for my setup but I have a few questions.
Is there any signal loss compared to a single yagi setup and if so how much? I would assume there would be some loss in the extra connectors.
Do they have to be aimed 180 degrees from each other or can you do other angles? For what I would want the angle would only be about 70 degrees.
If I can do about 70 degrees if they are on the same mast how much height separation between the two antennas would be needed?
Any other disadvantages to this setup?
