WS1080: Question about scanning
buckbull
#1
so i am reading about scanning with the 1080 and from what i gather its a no no to have conventional frequencies and some talk groups (800 mhz) all in the same scanlist . is that correct ?
rwier
Phoenix, AZ
#2
Where did you "gather" that? Both TGs and Frequencies are "assigned" to either none, one, or more than one TG.
hiegtx
Dallas, TX
#3
Are you confusing the scanlist with the systems?
You cannot have talkgroups in a conventional (non-trunked) system. Nor can you enter conventional frequencies within a trunked system. However, a scanlist can have a number of systems. Some of them may be conventional, others trunked systems of various types. You can have different types of systems, all tied to the same scanlist.
buckbull
#4
I was told its easier for the scanner to pick up transmissions if your have all your talkgroups in one scanlist and all your conventional frequencies in another .
