Hey all, I used to listen to Tri-Met (the bus system) when it was analog. Now that it's digital, I get the channels on my new scanner but there is little to no activity. Just wondered if anyone else hears activity on those talkgroups. Thanks.
Which scanner are you using? If using a database scanner, such as Uniden's HP-1/-2, 436- or 536HP, or Whistler's WS1088 or WS1098, do you have all of the corresponding service types enabled? Also, if a database scanner, are you using just location, range, and main databasr, or using a Favorites or Scanlist?
You might also consider having your thread moved to the Oregon Forum. Somone local would be more likely to see it there, and could have additional insight on the system. To do that, do
not create a new thread. Instead, click on the
Report in the lower left corner of one of your posts, and request that a moderator move your thread to the state forum.
