fuzzymoto said:
So you have a Kreco discone up and an ST-2/Scantenna and the Kreco does better?
I never said I have a Scantenna up. I have said in previous posts that I won't use crappy antennas, which I consider the scanntenna to be. But I digress. Define "better"? The scanntenna is nothing more than several monopole antennas in parallel. The element that is closest to resonance is the element that contributes the most to the signal captured and sent down the feedline. Gain is minimal on some frequencies, negative on others. And they fall apart in wind storms.
Kreco's discone antennas are ruggedly built, professional grade antennas. Gain is consistently less than a dipole, but not by enough to matter. They will take heavy ice loads, 100+ mph winds, and pretty much whatever you throw at them. I've installed these on 9000 ft mountain tops and they last year after year after year.
So, by my measure, they're better.
fuzzymoto said:
I've read hundreds of antenna threads on here and I think I've only ever heard Kreco mentioned a few times. Looks like their widest-band discone runs about 150Mhz to 1200Mhz.
That's correct. What's your point? If you're a professional in the industry, building radio sites for systems that have to be on the air no matter what, and you need low band, Highband, or wideband antennas, Kreco is where you go. Especially if survivability is a factor.
fuzzymoto said:
So why is there so little use of the Kreco if it is better than the ST-2? I can only assume they are expensive or not as wide-band?
Let's clarify that. There is little hobby use of Kreco antennas. Go up to a busy mountain top here in southern california, and you can't swing a dead cat without hitting a Kreco antenna. Yeah, they're expensive. But I don't scrimp when it comes to antennas. You may argue that they're not as wideband. This is true. I prefer to handle that issue with multiple antennas and multiple radios. For those that prefer the Scantenna, be my guest. But don't be surprised when they break, and then complain about it. They're cheap, consumer grade antennas and I think they're junk.
