Question on HP-2
#1
I just recently bought the Home Patrol 2. Connected to Sentinel to check updates. After updating it now says welcome to HP-1. Anyone ever see this. Says firmware 1.05 Sub firmware 1.02 database 12/11/2016
Am I missing something ?
fxdscon
#2
Open the profile editor in Sentinel, click the "Miscellaneous" tab, under "owner information" change it to anything you want and write it to the scanner.
You can also change the opening splash screen to whatever you want by editing the graphic on the SD card.
