Questions (3x)
AC0RV
Park Hills, MO
1.Who is the Parent agency for the Commerical Vehicle Enforcement Officers )the one's who Inspector the 18 Wheelers and such) and the Commerical Stations (the ones where you get your Brake Tags)
2 Also who is the parent agency for Weigh Scales) ?
3 I am looking Response Codes (i.e., use Engine Medic XXX This will a Delta response and so on)
Thanks.
bdzig
Manchester, Missouri
Not sure what exactly you are looking for on the third question. The response levels are Echo, Delta, Charlie, Bravo, Alpha, and Omega, based on the seriousness or priority of the call. This shows the matrix of call level to response needed:
The call type codes are hard to find, as Priority Dispatch has gone after people posting the codes, including Radio Reference.
bdzig
These are the responses levels. Basically, the higher priority or worse the nature of the call, the higher it is classified. On this chart, the higher the priority, the further to the right and down the call is classified. Anything on the left (Alpha, Bravo) does not need ALS care (paramedics) and could be handled by EMT-Bs.
