Questions about an osj 146/440 antenna.
medziatkowicz39
WEIRTON
I purchased an osj 146/440 antenna. Is there anything I should know before installing the antenna to make sure I get the best performance out of the antenna? Am I supposed to remove the red caps on the antenna or leave them on? This is replacing an diamond 510hdm antenna if that makes any difference. I am also planning on putting it on my dx engineering 46 foot collapsible mast. Thank you for any help or advice.
Don't remove the red caps.
Mount it at the very top of the pole so the mast and antenna elements are not adjacent to each other.
If this is a permanent installation, make sure you properly waterproof the connection. UHF connectors are not waterproof.
