Quick Call and NOAA WX radio
marksroberson
Florida Panhandle
I have a Motorola HT1000 VHF I use for Ham repeaters, and I also have the 7 weather channels programmed in. but i would like to use it as a weather alert radio but when i set up Quick-Call it seems that it uses 2 tones, and there must be a delay between tone 1 and tone 2. using the 1060 Hz tone for both tone A and B doesn't seem to work due to no blank space during the 1060 Hz tone during a alert. Should I use single-tone? and how do I set up single-tone in the channel edit mode?
RBMTS
Make sure you set the channel personality (for the radio frequency) to be a QuikCall type receive. Then select "Long Tone B". That is used for a single tone like what would be used for NOAA.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
And I do believe that the correct alert tone for NOAA is 1050 hz.
Just select Long Tone B. The timing is standard, and I don't think you can alter it in the software.
And, in standard, Quik-Call II, there is no gap between the A tone and the B tone.
