quick call II
ncjones28677
Statesville,nc
I have the Motorola xts 5000 trying to set the radio to receive and act as a pager .
I have the conventional setup with the local fire department. I have signal type set for quick call II. The quick call II tab is checked for selective call decode . Do I have to set the ID list?
And I have the system tab set with the fire tones a-b
rich1125
in conventinal personality did you click tab for quick call 2 and put in the system number.
ncjones28677
Statesville,nc
I have the conventional personality set for signal and the tab for quick II set and the system 1 set with page tones
The pl is set. The conventional is set for receive only with scan off . The squelch is set standard
rich1125
let me ask you said it is 2 tone correct , go back into the quick call settings and look at the tone format as ab tone / ab b/ long tone check that . by the way do you have a daily tone test ? if so what time . in the meantime i will get my friends radio i did , we will get you through this.
