BCD325P2/BCD996P2: Quick Key Differences.....
Ishmole
Walden, NY
Can someone explain in simple terms what the difference is between Group Quick Keys and System/Site/Search Quick keys. I have programmed and used many of the 99 System/ Site/Search Quick Keys and am familiar with them. Are the 10 Group Quick Keys any different? Do they serve another purpose?
TIA
Mike
hiegtx
Dallas, TX
TIA
Mike
On the non-database DMA scanners, such as your 996P2, Group quick keys can be used to sort out the frequencies (conventional channels) or talkgroups (trunked systems) in use. For example, in a large city, there may be quite a few channels or talkgroups in use. The Groups could be used to split out various agencies. One group has Law Enforcement entries, another is dedicated to Fire, yet another to other services. Or, in a county, you might want to put each city in a different group, which would let you to concentrate on a large incident in that location, without also getting routine traffic from the other municipalities. You can, of course, just lump everything into a single group if that's your preference.
For the non-database DMA scanners, to toggle a Group Quick Key on or off, you have to be scanning that specific system, then preface the group key number by first pressing the function key. Alternatively, if you were not (at that moment) scanning the system where you wanted to turn a group key on or off, then you'd have to first put the scanner in Hold mode, scroll to he system where you needed to change a group key status (on to off, or off to on), then press Function plus the key number.
Group quick keys serve the same purpose as the Department keys on the database scanners (x36HP & SDS series). But toggling a key on or of takes the extra steps noted above. For the database scanners, the Department key can be accessed more readily. by pressing xx.yy.zz while the scanner is going though the systems programmed. (xx = the Favorites List's key number, yy = System's key number, and zz= the Department's quick key number.) The Groups, in your 996P2, are what the x36HP & SDS series scanners call "Departments".
iMONITOR
Silent Key
S.E. Michigan
Ha, you beat me by 2 minutes! :)
ofd8001
Louisville, KY
Imagine a file cabinet: The System Quick Keys unlock the file cabinet. The Group Quick Keys open/close individual file drawers.
To toggle off/on a System Quick Key, press the number. To toggle off/on a Group Quick Key, while the scanner is actively monitoring the system, press the function button, then the group quick key number.
tvengr
Well Known Member
Baltimore County, MD
Hopefully, this will answer your questions.
  • Uniden Scanner Quick Key Instructions..pdf
