Quick Q: CP185 Narrowband
RadioDitch
Nomadic
Quick and simple. Can a Radius CP185 be programmed 12.5kHz bandwidth (narrowband) channels?
Thanks Ladies & Gents,
Matt
RadioDitch
Nomadic
SteveC0625
Northville, NY (Fulton County)
I've actually read that article before. Thing is though that article references issues with 6.25 and 2.5kHz. Based on the answers here, it doesn't seem that there are any issues with 12.5, which is what I need.
While the 185 works well on most existing frequencies, as the new splinter frequencies get issued, 2.5 KHz increments will matter, big time. If the radio won't program in 2.5 KHz steps, some day down the line, it will be problematic.
If you want to avoid this potential problem, take a look at the CP150 or the CP200. Depending on what options you need, one of them might work much better for you.
radiodog2009
CP185 User's Manual
I just purchased two new CP185's and looking for a full user's manual. I've been all over the Motorola website without success. I would also like to find a way to program the voice scrambler function to operate.
If you have any suggestions, I would appreciate hearing them.
Thanks in advance.
RD2009
