BCD436HP: Quicksave frequencies from discovery review?
kodo
#1
Im going through the run results of a recent discovery scan. I'm seeing some stuff that I'd like to save. Is there a way to quick save the found frequencies to your favorites, like you can do when doing a live search? What about a quick way to save frequencies from replays/recordings?
kodo
#3
Odd. I mean the main reasoning behind wanting to do a discovery/search would be so you can find new frequencies to assimilate into your database, right? Why not make that process as streamlined as possible? Must have been an oversight. Hope they fix that with the next firmware update.
It would be nice to be able to quicksave freqs from replays/recordings also. The ability to permanently save temporary replays would be nice also.
