Quieter External Speaker for MCS2K
cpg178
Hello, currently have a HSN4031A external speaker for use on my Model 3 MCS2000. I primarily use it in the home for monitoring the local FD Dispatch. Problem is that even with the volume knob on the radio turned down, the tones come through obnoxiously loud. Does anyone recommend a smaller speaker I can hook up that will still give me the nice Motorola audio quality but without blowing out my ear drums? I tried doing some research and most M speakers I can find are 13w, the one I have is 7.5w I think.
K2NEC
NA
You don't have to use a Motorola speaker. My friend had one of these in his car and seemed to be happy with them. As long as you know how to splice and solder, you should have no problems getting it working.
cmdrwill
So Cali
That speaker is made to be loud.
Probably a 8 ohm speaker, so add a 4 or 8 ohm resistor in series and that will reduce the "voulme" a bit.
cpg178
Thank you everyone for the replies, am moving shortly so once I get settled in will have time to figure out a good solution. Am also looking into getting a RCH3000, can get one under 150 on eBay and that solves my issues as well. Anyone happen to know if it matters what model RCH3000 I use, i see there is different models for the spectra and MCS.
