R1225
wesley2099
I recently got a gr1225 uhf repeater setup and when testing I found out it’s not outputting and power hardly at all. I am not able to find a decent priced r1225 replacement radio and am wondering if a regular m1225 could be used and made to work. The r1225 has the ribbon cables and mini uhf port on the front of the radio. Any help is greatly appreciated.
ramal121
Lots and lots of watts
Calif Whine Country
No. A mobile and a R1225 are two different beasts. Not compatible.
Pull the PA heatsink off the back (two torx screws) and pop the shield off. Give it a sniff test and see if there is any burnt/bad solders around the big final transistor. Usually the case for no power.
wesley2099
Hey thanks for responding I am a newbie and have almost zero solder experience but I will see what I can find. Are parts hard to come by for these or is this normally a resolder job.
RadioGuy7268
PA
The PA's are notorious for burning up on R1225's that were run at high power. Even the mid power setting requires a ton of airflow if you run anything over a 50% duty cycle.
The GM300 mobile is often used as a donor for PA/final components, as it is the closest kin to the R1225. If you have zero experience, it's a pretty long jump. Re-soldering vids are out there on Youtube and repeater-builder.com is the go to resource site. You may even find some repair manuals and schematics.
The R1225 reference page on RB
wesley2099
Ok so I took everything apart from what I can see it looked ok until I got the pa cooling fins and I can see some burnt stuff going on.
ramal121
Calif Whine Country
I'd say the emitter on that final looks pretty suspect. If you're not a solder guy could you find somebody to carefully clean that up and reflow the solder all the way around? Unless the leads and caps are over a big black hole usually there's no damage and this might get it going again. With all the flux around those parts I'd say this has been done at least once before.
wesley2099
I appreciate all the help, I did my best to resolder and flow, I was not able to get it to work. I have ordered a used m1225 to use as well I figure I will use the bad radio as a recieve and the m1225 as a transmitter for the gmrs repeater. Now I just need to figure out if a m1225 can or is possible to make it like the r1225 is with a mini uhf receiver on the front faceplate and a spot to connect the ribbion cables for the controller.
