R7 battery error
thegmaniac
Motorola tech support triage is completely clueless.
I’m getting this error and they don’t know and certainly I don’t know, what to do.
Unknown battery.
Can’t recondition battery or nothing.
Any ideas.
sjaltavilla
Vermont
Unknown battery.
Any ideas.
If I recall from when I first got my R7, I got the same issue. The only way I found to fix it was to go into CPS and make sure that the radio certification type is set to none. I think there was also an option to check if the battery is Intrinsically Safe or not. You want to leave that off. I'm pretty sure doing those two things cleared the error for me.
thegmaniac
Did that this morning with level 2 tech. It was all set properly. Did the firmware update and still unknown battery. They think it’s the radio. I’m sick over this cause I don’t know what to do. I do not want a refurb on a radio less than a month old.
Firebuff880
Boynton Beach, FL
Are you sure you have a IMPRES battery ? Because of supply chain issues some people have been receiving batteries without the magic chip in them. Try another battery if you have one from an XPR-7000 Series, otherwise you should go back to the dealer for a replacement or refund.
thegmaniac
Yes 🙌 I’m sure. I just got another battery and it’s still conditioning as we speak.
thegmaniac
I have a picture of the battery (original) but it won’t let me upload it. Says it’s too large.
com501
IF you send the radio in under warranty, you get back a new radio, with the same serial number as the old one. Motorola does not repair those radios. 'Swap and drop'.
