Great advice has been given above.
I worked for about a decade for a company that used Motorola CDM-1250's, Vertex VX-3200/4200, Icom IC F-1020/2020, and now XPR4550 Trbo mobiles on vessels for pretty much the same use you describe. Some were mounted under the steering console, with glands for the mics and antenna penetrations. Others were mounted in boxes, those smoke tint front panel boxes work well. Others were left mounted exposed under the house roof, which rusted the metal cases, but took several years to do so.
For 1km range, we also had handheld Vertex Standard and Icom water resistant radios that allowed for commercial LMR frequencies and marine VHF use in the same radio. Vertex HX-370 was one model used. These radios can take some water spray, are handheld, and operate on VHF marine frequencies yet allow for the addition of some commercial VHF channels. You mentioned UHF use, so you would need another radio, or a VHF licence, but may be easier for your purpose.
Thanks for the reply. Much appreciated, will look into it.
