Radio Shack 106
kc2asb
NYC Area
This thread from a few years ago dealt with a PRO-106 displaying a heap error, though the error code is not the same as what you are getting. It also links to an even older thread on the same topic. Might be worth reading through.
Good luck.
RMason
Mississippi / Colorado
see also regarding discussion of: Heap Error 22401F 2247
RMason
Getting >rror Code Heap Error 22401F 2247 i I touch any key
As shown in the above linked threads, heap errors are usually caused by a programming error such as talkgroups not assigned to a trunked system or no scanlists (aka "banks") enabled. Did you recently change your programming?
node1
richmond indiana
Thank You I belive that is the problem I had programed a TGIF but have not tried anything with it two weeks ago. Looks like I have reprogram the scanner. It dosn't respond to anything.
Ensnared
Waco, Texas
When I used to encounter this with my GRE PSR 500, it meant some of the talk groups & TSYS were not connected. In other words, you can program the TSYS without the talk groups. There is a way to find the affected TSYS and fix things.
node1
richmond indiana
Good luck.
We found the problem now to correct it Thank You
