dosboot
Has anyone tried the Radio Shack Antenna, if so does it help bring in 800Mhz Freq. ?
LGLHOOK said:I.....sometimes I get better reception not using an antenna at all......
jrmarlowe said:I have the RS 800 - does a little better than your stock duckie. However, I've found the Radioware Seeker 800Mhz to be far superior. It's a bit more expensive at $40, but you know the old saying... I can pick up neighboring county systems at 30+ miles away.
http://www.radio-ware.com/products/sek800.htm
phil_smith said:Isn't that bad on your radio?![]()
phil_smith said:hmm.... that maybe my next investment! thanks for the info!
LGLHOOK said:Tell me how it is bad on the radio.
---GUMP---Joseph11 said:It's only when TXing. You can RX fine without an antenna.
sta18ff said:I will soon be buying a 396 (when income tax return arrives!!). I wonder if they will ever make an SMA version so it could be used without the SMA-BNC adapter.
