So on a quick first pass it looks like the serial number starts with a letter followed by numbers. I have a C001786 so I assume I have a "C" version.
I got the radio benched, covers off, volt meter out and started at the top with the "reception check" flow chart in the service manual, which the first step once determining you have an issue is checking the DC-DC converter and second step checking the voltage regulator. The DC-DC should have an output of 5v, mine comes in at 5.034. Moving on to the voltage regulator Q30, I have high voltage readings on all three legs of the PNP transistor.
I am 0.5v high on the base, its called out as 13.0v, I read 13.5. The print shows about 0.1v drop from collector to emitter, 13.8 to 13.7. My voltages are 14.25 and 14.25, so essentially its high, and doesn't really reflect the voltage drop I should see. So, do I have a leaky capacitor issue, or actually a "mostly bad" voltage regulator? At any rate, it looks like as others have suggested, we have some sort of power supply issue. This I think I can handle, determining a bad component or two and doing a parts swap. Hopefully someone can maybe pull up a copy of the schematic and offer some guidance?
C144 looks like the big ole 'lytic cap for filtering connected right with Q30 voltage regulator. Physically there's no obvious signs of problems. If it was leaky or failing, would it cause the voltage to be high or low at Q30, or does it just depend?
