Radio Shack Pager
i386
GMRS WRFB260
Georgia
Just curious anyone remember these? What frequency did they use? I know it as an Antenna connector SO-239 I am thinking either the CB Band Maybe between 15 and 16 Ch 15 26.135 Ch 16 27.155 it skips 26.145 also between 3 and 4 there is 26.995. I know those might me reserved for RC cars. I am thinking the pager might use VHF if not in the CB band. And I know I cannot hear anything just wondering what frequency. I might try to grab one and play around with it with Antennas. I have seen restaurants use pagers when there are long waits. Could they use one of the MURS channels? Because I did hear a funny data sound on MURS channel 4.
76755
dispatch235
Central Missouri
If you knew someone with a frequency counter it would be easy to figure out...that is one item I don't remember Radio Shack had. I do remember they made a wireless intercom system for homes.
n9lob
EUREKA
I used one of those systems back around 1999. They were in the CB band but I think they might have been in between channels. I found this looking at the 1998 RS catalog online with more info.
i386
GMRS WRFB260
Georgia
That system operated on 27.255 MHz.
LOL That is CB Channel 23. I was thinking between 15 27.135 and 16 27.155 so it would be 27.145 but I also know 27.145 is RC Cars between 3 26.985 and 4 27.005 there is 26.995. If I could get one I would try to find it on my scanner. Frequency counter would be easier but scanner will do
i386
GMRS WRFB260
Georgia
Tvengr mentioned
Try these:
Ch.A 49.830
Ch.B 49.845
Ch.C 49.860
Ch.D 49.875
Ch.E 49.900
Also 27.255
Channel E is 49.8900 I never heard anything on 49.900 I even have a Maxon 49-HD 5 channel and E is 49.890. But I have heard other people say 49.900 was part of the 49 MHZ RC car and walkie talkie band
kruser
Well Known Member
W St Louis Cnty, MO
Yep, back in the day, CB channel 23 was shared with RC and other devices.
i386
GMRS WRFB260
Georgia
Also channel 14 I think I know Radio Shack had some CB Walkie Talkie that was Channel 14 only.
DJ11DLN
Mudhole, IN
Back in the early '70s there were a lot of walkie-talkies on 27.125, made by several different companies. Mine were Midlands and had the code key, of course.;)
i386
GMRS WRFB260
Georgia
I lived next door to a radio station. I remember getting a Walkie Talkie for Christmas and it was unusable because I could hear the radio station. I took it with me to my Grandmothers and it worked just fine there. I am not sure if it was 27 Mhz or 49 Mhz I think it was 49 Mhz.
ecps92
Taxachusetts
Google is a friend
tvengr
Well Known Member
Baltimore County, MD
Tvengr mentioned
Try these:
Ch.A 49.830
Ch.B 49.845
Ch.C 49.860
Ch.D 49.875
Ch.E 49.900
Also 27.255
You are correct. Channel E is 49.89. My Dumb!
i386
GMRS WRFB260
Georgia
Google is a friend
WOW I also found this 27.2550 Authorized in Part 95 of FCC rules. 25 watt power limit. Shared with Citizen's Band Radio service.
What if I had one 25 Whatt and a very good CB Base Antenna. I wonder how far it would reach.
IC-R20
LoBand Nation
25 watt carrier actually. A fully modulated signal would be at 100 watts. Very good indeed. I have this radio shack pager unit actually and connected it to a plain jane 1/4 wave ground plane antenna, unity gain, and it was able to set off the little beeper on my belt across town. It would be interesting to connect it to a friend of mine's Jo Gunn 25db flat beam. Back when 11/10 meters was still propagating great that thing got out amazing with my old radio shack Realistic CB i turned one of the POTs inside to get the power as high as it would go. 30 watts dead key 35 watts swing. I miss the old CBs with big dead key.
