how do you program txwarnp25 codes into a Pro 94? I did just like the manual said, and nothing.
after programing all the 800 #s I hit trunk and search, and nothing.
Confused, where should I go to get the right info?
You won't be able to monitor the
TxWARN P25 system with a Pro-94. That system is digital only, and the
Pro-94 is an analog only scanner.
You can, as it appears you've found out, monitor the analog TxWarn
system, though, with the Pro-94.
To monitor the P25 system, you'll need a digital trunk tracking scanner.
Something like the
Pro-106 (on sale for $299.99, but sale ends today, however, they seem to be running a sale every month or so), the GRE
PSR-500 (same scanner as the Pro-106, just different front panel layout; GRE makes the 106 for Radio Shack); or Uniden
BCD396XT. (The discontinued, but still available
396T would also work.) All of these can sometimes be found in the classifieds here, or on eBay, among other places. There are also base/mobile versions of the above handheld (portable) scanners above. See
digital trunktrackers in the Wiki for more choices. What you need is a scanner that can handle the system type "P25 Standard. For each scanner, the systems it will work on is listed under the category "RR System Compatibility".
GRE's
PSR-800 or Uniden's
Home Patrol (HP-1) would also work. Those are both scanners where you enter your location, and the programming is pulled from the RadioReference database, which is stored on a memory card in the radio itself.
