Radio Shack/Realistic 5 pin mic
Texas
I haven't been able to find a pin out of the 5 pin midi some of these cbs use. I've got a trc-481 that I keep in my jeep and can no longer stand the channel buttons on the mic. I've got several Motorola microphones laying around and was just thinking I might wire one of those up but I have no reference to stay with.
Sent from my ME173X using Tapatalk
JayMojave
Mojave Ca
Hello PKY: Look at CBTricks,com they have the diagram for the TRC-481, its at:
Realistic TRC-481 (21-1550)
I would think the 481 Mic uses a low impedance Mic, and is fed a voltage to make it work.
The old Motorola Mic's I have converted for CB use, I removed the Motorola Mic element, unshielded mic cord and PTT switch. Added in new Electret Mic, shielded mic cord, and a real PTT switch from some left over CB Mic. There are many types of Motorola Mic's I am sure you can run down there diagram on the net.
With some experimentation the Motorola Mic Element might be able to work, as its a low impedance Mic and also requires a voltage to operate. It has a transistor that acts as a small gain amp and or a buffer.
Jay in the Mojave
