Radio spec/performance comparison
Gadgetmann
Ingham County, MI
#1
Are there any discussions/comparisons between the
Motorola APX-6000 and the Harris XL-200P?
This would be performance on a P25 Phase 1 or a Phase 2 system.
Is one superior over the other?
Receiver sensitivity? Filtering?
Will they perform the same, different?
#2
The Motorola has better selectivity which is the most important receiver spec.
It also has better sensitivity.
Texas
#3
I've found often times radios tend to exceed their spec'd ratings. It's hard to know exactly which is better until you get a couple to test independently, its difficult to actually say what's better.
