Radio stations with the 296D
Alpha432
Downriver Area, Michigan
I programmed in some radio stations with my 296D here in Michigan. They don't come in very good. For example I have 88.7 programmed under conventional, with the FM setting and it is choppy and very off and on. Why can't this Hi Tech digital scanner recieve simple radio station frequencies??
ab8sf
Southwest Michigan
My reception was OK but not exceptional. Very location dependent. I suspect the antenna is not optimized for the FM broadcast band.
Jim AB8SF
