RadioCapture.com Tech Demo
f0urtyfive
Hello all,
RadioCapture.com is an application I've been developing (that is currently denver-based, so I'm posting here). I'll spare the lengthy explanation and get right to the URL.
RadioCapture.com - Tech Demo
f0urtyfive
Now, as to why this is any different from any other radio stream (aside from the way it is displayed); RadioCapture.com uses a wide-band radio to capture all of the channels of a trunked radio system at once, allowing the user to not only use it the same way he would a scanner, but also not ever miss a call because every channel is captured simultaneously (unlike a scanner, which has to switch between the voice and control channels).
greenthumb
Colorado DB Administrator
Are you using the Ettus receiver for this?
