Radioddity gd-77 DMR
Palmerton, PA
Hey guys,
So working on setting up a DMR radio for my dad and i have been around the block many years of the analog ham radio stuff since i was a kid. However i recently got the above named radio and programmed it to how it should be and all i get is a "connect fail" with multiple repeaters. When i research the repeaters on the site the grid shows im well within range of the actual repeater. Any ideas? Thanks!
chief21
Summer - Western NC; Winter - Tampa Bay FL
I'm not familiar with the GD-77, but all DMR radios are programmed in a similar manner. At a minimum, the frequencies (both TX and RX), color code, time slot and talkgroup must be correct. In addition, there are various other digital settings which could prevent the rig from transmitting.
If you believe that your programming is correct, it is possible that you might not be close enough to the repeater(s). It might be worth a short trip to the immediate area of a repeater to see if the radio works there.
If you're not confident in your programming, there are lots of DMR-related web sites and youtube videos to get you up to speed. DMR is quite different from analog!
jdifabio
Swansboro, NC
GD 77
Hello, I just got ,my first DMR radio a few days ago, the GD 77. The Radioddity facebook page has a large amount of information. I did not experience your particular error, but I had enough of my own, Research, Research and more BUT its a lot of fun. Good luck Joe
KD2LZS
Lincoln Park NJ
Hi All,
I am having the same problem, I have followed all the instructions to programming the GD-77. Watched several tutorials to make sure I was doing the right thing. Yet whenever I try to transmit, I receive "Connect Fail". Any thoughts? Confirmed all the TS, Freq., Color Codes are correct. Thanks.
tunnelmot
Conroe, TX
I don't personally own one, but I heard that the GD77 HAS to have the rx groups filled in for each channel/talkgroup to work properly.
Try that
crash1
Tampa Area
I have this radio check to see in the software if you have received only checked I do believe that it does say failure if it's in receive mode only
AJ6BL
Westlake Village, CA
I am also having this same problem on my local repeater. The only way I have found to workaround this is to set both the tx and rx frequencies to the same freq. This seems to allow it to transmit although on the wrong tx freq. Anytime I make an offset (even if I switch the tx and rx freqs the wrong way) it gives me the "connect fail" error. Ive confirmed my codeplug is setup properly and have even reached out to the repeater admins who've confirmed this. It seems to be related to the radio. Any suggestions?
usswood
Terre Haute, IN
A screen shot of your programming software would go along way
AJ6BL
Found a Fix!
Let me start by saying this is a very dangerous fix and can possibly brick your radio. If you are uncomfortable proceeding I would suggest waiting for another firmware to come out which will (hopefully) address this problem. None the less I found a fix for this issue. From what I've read "Memory and / or factory resetting the GD-77 can corrupt information in the RF alignment data block at address 8F000 onward". Also from what I read, this only affects GD-77s with firmware later than 2.6.6. The link below will walk you through the fix (about 3/4 down the page). You will be doing a very low level fix and editing the radio's source code with a HEX editor. Its actually not as scary as it sounds as long as you follow the directions exactly. (measure twice cut once...) That said, I will repeat, you can possibly brick your radio, so be very careful making this change. Good luck!
Radioddity GD-77 Alignment / tuning / modifications (mods)
