Looks interesting , Will this radio do 477MHZ analogue TX ?
No. Unless somebody comes up with a wideband hack at some point, it is currently software limited to 470 MHz.
Just received mine today. I'm surprised to read that no one has had any anti-virus/malware issues with the software.
On my work laptop, Symantec Endpoint stopped it cold. On my home PC it was stopped by Windows Defender and then, when allowed through, destroyed by Malwarebytes. This occurred with the latest version of the software and its predecessor.
Curious as to whether anyone else has come across this "anomaly".
Associates any available RX Group list to the channel for reception. The user can listen to any Group in this list when there is any activity on it and talk back within the Group Call hang time. This is also known as a Group Scan. Selecting the None option disables the user from receiving any Group Calls on this channel, except when the Call ID is the same as the Call ID of the transmit member. The Call ID from the Contact Name is automatically added to the RX Group List on this channel by default. This allows the user to receive this call, even though this feature is set to None. This is a channel-wide feature.
I have what I believe to be an unusual issue occurring with my GD-77. As far as I can tell the radio acts like it's in promiscuous/monitor mode regardless of the fact that I have that feature toggled off via the button I have programmed for it.
If I have the radio sitting on a tallkgroup that uses slot 2, I hear traffic from any of the others that are also using slot 2 when they become active. This also happens on slot 1. All talkgroups seem to be correctly set up and are in appropriate contact lists.
Curious if anyone else is experiencing this issue and if so if there's a fix for it. The option to monitor everything is nice, but I'd like to be able to defeat it as well. Thanks.
No it doesn't. You'll have to manually pick the repeater/site that you want. Same as any other low end DMR radio.
