Radioddity GD77 and Chirp software
radiochimp52
Florida
Downloaded the latest Chirp build and I still do not see a GD77 listed like other Radioddty radio,
Yes I know that the GD77 is a bear to program and they did have a couple of "correction" builds that wher causing some lockups after loading Has Radioddity "Orphaned" the GD77?
alcahuete
Southern California
It's not a bear to program at all. No different than any other Motortrbo radio when it comes to programming.
CHIRP does not support the GD77. There's a community version of the firmware/CPS you can download, but I'm not really sure it makes it any more easy to program.
khaytsus
I suggest using the Community Edition, as previously mentioned in this thread.. Roger Clark is the main website, there's no direct link to the software as he posts updates in blog posts essentially, so that's the latest place to look. It's the OEM software, enhanced to make it easier to use and allows some limited reordering of items etc. It's 100% compatible with the OEM, so I'd suggest using it.
khaytsus
Chirp does not support any DMR radio.
Apparently there is some limited support for the MD-380 in CHIRP, if not in mainline, in other places. But I don't know what the support level is. But yes, DMR is a very different animal and requires a different structure.
The Community Edition editor for the GD-77 is okay, not great, but okay. You can rearrange some stuff but a lot of it is in whatever order you enter it. I love editcp for the MD-380 though since it's so flexible and lets you order things and fix things others don't allow.
N4GIX
Hot Springs, AR
The difference between formats is akin to that of a flat-file database and a relational database. "Chirp" is designed to create a flat-file database, or in simpler terms a single line entry which is storable in a comma-delimited format (CSV) file.
Digital however relies on having multiple databases that are separate tables of information that are "related" to the other tables, something which Chirp simply was not designed to handle given that every stinking DMR radio has a noticeably different method of "relating" those databases!
