Radion Station Broadcast (?)
Lyman
This evening I turned on my Pro-96 and while in Scan mode it stopped at 161.76000...wherein I found myself suddenly listening to Latino dance music. I cannot save if this was an AM or FM station, though the scanner was in FM mode.
Having come back to the scanner about an hour ago, the music is gone.
Can anyone shed some light on this? If this was in fact a radio broadcast (extremely crystal clear) this has me stumped as I thought scanners cannot pickup radio stations - period. Why is that, btw?
Thanks,
Lyman
jb872033
Cromwell CT
they cant recive because FM stations use W(ide)FM and scanners recie N(arrow)FM, and i wonder the same thing...i have heard FM stations in scanner before on both V+UHF...struck me as odd too....
JB
Zaratsu
Eastern Connecticut
I get an FM feed of a AM radio station on 460.2500
I have no clue.
Must be a feed to a backup tower or something. If you drew a line between the broadcaster's main transmitter 20 miles away, and the big antanna farm on a hill that everyone in the area uses 1 mile away, it would be a line right through me.
n7lxi
Lancaster PA
Thanks,
Lyman
161.76 is one of the Broadcast "RPU" or Remote Pick Up channels. It's can be used for sending live broadcast audio from wideband equipment, commonly called a Marti, back to the studio or for sending pre-delay audio out to a remote broadcast site to feed a PA system, IFB cueing or as an emergency studio-transmitter link.
Find out more about Marti gear here: http://www.martielectronics.com/hierarchy/secondary.php?maj=201&sec=210
bobmich52
TSX, 460.250 ??
That's East Hartford Pd Ch 1
Can't say I've Heard AnyThing Other Than Ehpd On It
If Your In The Mall Area, So Much Radio Traffic, Anything Is Possible I Guess
The Only RPU I Have Heard Recently Around Here & Not Too Often Is Wtnh, Usually Between 12/1 pm.
jakegday
Banned
JB
true but not true, your explanation is correct, however a scanner CAN receive in both narrow and wide FM, the bcd396t does it, when you activate the "fm radio" service search it searchs in wide fm
Don_Burke
Southeastern Virginia
bobmich52 said:
TSX, 460.250 ??
That might really be 450.250.
We have several RP channels in use here in that region, some for IFB.
Zaratsu
Eastern Connecticut
bobmich52 said:
TSX, 460.250 ??
oh, wait, wrong freq, nevermind. It is 161.7600 that I'm getting WTIC am on.
I was looking at the wrong scanner, the one WITHOUT alpha tags:lol:
Microwavemike
Dallas Tx
Broadcast RPU Frequencies
RPU / STL BDCST AUXILIARY FCY LIST 74.402, 74.462
MAXIMUM POWER IS 100 WATTS, WITH 15 WATTS MAXIMUM ON BOARD AIRCRAFT
======== GROUP A (KHZ) 10KHZ BANDWIDTH, A3 ONLY ======
(a) 1606 (1)
(1) 1622
1646
GROUP D === GROUP E === GROUP F === GROUP G === GROUP H = (MHZ)
(2) 40KHZ BANDWIDTW, 10KHZ DEVIATION
25.87 (2) 25.91 (2) 25.95 (2) 25.99 (2) 26.03 (2)
20KHZ BANDWIDTH, 5KHZ DEVIATION
26.15 26.17 26.19 26.21 26.23
26.25 26.27 26.29 26.31 26.33
26.35 26.37 26.39 26.41 26.43
[ A3E,F3E,G3E,F8W,G8W EMMISSIONS ]
====== GROUP I GROUP J (MHZ) ======
(3) 26.07 (2) 26.09 (2)
26.11 26.13
26.45 26.47
====== GROUP K1 (MHZ) (3,8) ======
(4) 30KHZ BANDWIDTH, 5KHZ DEVIATION
152.87 153.05 153.23
152.93 153.11 153.29
152.99 153.17 153.35
[ A1A,A2A,A3E,F1B,J3E,F2B,F3E,G3E,F8W,G8W ]
NOT FOR USE ON AIRCRAFT
NOT FOR USE BY NETWORK ENTITIES
====== GROUP K2 (MHZ) (5,8) ======
161.64 161.67 161.70 161.73
161.76
====== GROUP L GROUP M (MHZ) (4) ======
(5) 25KHZ BANDWIDTH, 5KHZ DEVIATION
166.25 170.15
450.025 -> 450.975 MAY ALSO BE ASSIGNED TO CABLE NETWORKS-ENTITIES
455.025 -> 455.975
====== GROUP N1 (MHZ) ======
(6) 50KHZ BANDWIDTH, 10KHZ DEVIATION
450.050 450.350 455.050 455.350
450.150 450.450 455.150 455.450
450.250 450.550 455.250 455.550
====== GROUP N2 (MHZ) ======
450.0875 450.3875 455.0875 455.3875
450.1125 450.4125 455.1125 455.4125
450.1875 450.4875 455.1875 455.4875
450.2125 450.5125 455.2125 455.5125
450.2875 450.5875 455.2875 455.5875
450.3125 450.6125 455.3125 455.6125
====== GROUP P (MHZ) (6) ======
(7) 10KHZ BANDWIDTH, 1.5KHZ DEVIATION
450.010 450.980 455.010 455.980
450.020 450.990 455.020 455.990
TSL CHANNELS
====== GROUP R (MHZ) (7) ======
(8) 50KHZ BANDWIDTH, 10KHZ DEVIATION
450.650 450.700 455.650 455.700
450.750 450.800 455.750 455.800
450.850 455.850
====== GROUP S (MHZ) (7) ======
(9) 100KHZ BANDWIDTH, 35KHZ DEVIATION
450.925 455.925
(c) For licensing purposes, a single system will consist of transmitters authorized to use the following combinations of frequency groups in a single area:
(1) GROUP A
(2) ONE GROUP FROM GROUPS D, E, F, G, OR H; AND/OR EITHER I OR J
(3) GROUPS K1 AND K2, AND/OR EITHER L OR M
(4) GROUPS N1 AND R
(5) GROUP N2
(6) GROUP P
(7) GROUP S
FREQUENCY TOLERANCE 74.464
FREQUENCY BASE MOBILE <- TOLERANCE
1.6 to 2 MHZ
200W or less 0.01% 0.02%
Over 200W .005 .02%
25 to 30 MHZ
3W or less .002% .005%
Over 3W .002% .002%
30 to 300 MHZ
3W or less .0005% .005%
Over 3W .0005% .0005%
300 to 500 MHZ, all powers .00025% .0005%
STL FREQUENCIES (MHZ) (500KHZ CHANNELS, FCY TOLERANCE .001%)
944.5 946.0 947.5 949.0 950.5
945.0 946.5 948.0 949.5 951.0
945.5 947.0 948.5 950.0 951.5
jb872033
Cromwell CT
I eat my words...i knew that some scanners can recive WFM the thought didnt occur to me till after...Prolly shouldnt post when im tired...sorry for any confusion....
JB
Lyman
JB
No problem. I know the feeling.
Was tired yesterday, videotaping trains all day (for which the scanner is indespensible). After 41 years of watching trains I should have known better:
I was kneeling on the Eastbound tracks videotaping a train heading Westbound. Very loud, obviously.
Out of the corner of my eye I caught one coming on the Eastbound tracks...never heard it.
I was unaware that I could still move as fast as I did, or that my BP could raise so high so quickly.
Thanks for the information!
Lyman
Lyman
Thanks Mike!
Lyman
(a) 1606 (1)
(1) 1622
1646
26.11 26.13
26.45 26.47
161.76
166.25 170.15
455.025 -> 455.975
TSL CHANNELS
450.850 455.850
450.925 455.925
(1) GROUP A
(4) GROUPS N1 AND R
(5) GROUP N2
(6) GROUP P
(7) GROUP S
1.6 to 2 MHZ
Over 200W .005 .02%
25 to 30 MHZ
Over 3W .002% .002%
30 to 300 MHZ
Lyman
Thank you, and to everyone else who took the time to reply to my query!
Lyman
greghahn
Thanks,
Lyman
161.76 is one of the "RPU" frequencies that are auxiliary services to radio stations. RPU stands for "remote pickup unit", and that is the equipment that many stations have used for 40 years or more to do remote broadcasts from various locations.
This equipment can also be used as a "Studio-Transmitter Link" to get the station's programming to the transmitter site if the normal "STL" is unavailable.
Most broadcast stations have moved their RPU to the UHF band, 450-451 and 455-456 MHZ. But the old VHF frequencies are still good. The most common of thse are:
161.64 161.67 161.70 161.73 161.76 166.25 170.15,
though there are some licensed from 152.87 to 153.35.
