Radioshack Pro 405 Scanner
Tmmet003
I am having issues programming this scanner for the Houston, TX area. My dad purchased it and I am unfamiliar with the programming of these. I've read the instructions and used the list of frequencies found here but it doesnt seem to be working. All I ever get is static no matter what frequency I use.
Any help will be greatly appreciated.
Thanks,
KevinC
Moderator
Super Moderator
Somewhere other than home :(
Thanks,
Welcome to RR!
What exactly are you wanting to listen to? All of HPD/HFD requires a trunking and P25 digital scanner, of which the 405 is neither.
Tmmet003
Yes, I was wanting to listen HPD / HFD. He wants something simple. After doing some more research, I found this scanner isnt what I need. Is there anything you can recommend that would work for me ?
Thanks again.
