Radius CM200 Error
dixie729
Daviess Co., KY
I'm trying to reprogram a CM200. I'm getting an error.
Error # 512
Unable to read.
Check to see if radio is connected.
Radio is powered on and COM port setting is correct.
I'm using CPS R05.17
I'm using a programming cable that has multiple cables and is specified to work with the CM. (so it says)
Radio is on, and my COM port is correct.
Any ideas on the reason why I'm getting error 512?
Sent from my HTC One X+ using Tapatalk 2
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Search here and on the batboard. You need either an adapter or modified cable to program your CM200. Pins 1 & 3 have to be jumpered together to throw the radio into programming mode. We've been through this several times and this is gospel.
(FKN8096 is the part number for the adapter. You can also build one for cheap. Details in previous threads.)
dixie729
Daviess Co., KY
So I'll I need is the adapter and I can use my cdm cable to plug into the adapter and I'm good to go
SteveC0625
If you would read the other threads here and on the batboard, all of your questions will be answered. Yes, either buy the adapter or modify your cable or build your own adapter.
