Radius GR1225 VHF code plug needed.
P25Radio
Oceanside Ca.
Looking for a code plug to resurrect an old Gr1225 repeater. Communications from computer to the repeater is good. but get a code plug error 58. See if I can force another VHF plug into it to maybe make it come alive. I pulled the radio out of it and no tags. The only information I can find is as follows on the outer frame case.
Model H518B FCC ABZ99T3023 Serial# 780TBE0444 Unit is VHF range 2
P25Radio
Oceanside Ca.
I can get into the service mode and say change squelch deviation and write it but can not get into the main code plug the change freqs.
Kazzeki
I'm not quite sure if you still need it, but I'll send it your way. I happen to have rehabbed one of these crazy repeaters about a month ago after it being donated to me. It was going to end up or rather it already was disposed of in an electronics dumpster. Amazing lil fellas.
Anyhow, codeplug is incoming.
Kazzeki
Got it, cloned it, IT'S ALIVE!!!!!! AND SAVED IT! Much thanks! Programmed and re-read just fine.
So it worked? I'm happy to hear it! Hope you enjoy the repeater, it's very fun to play around with
rvanfreg
Hartsville, TN
I have the same issue with my radius 1225, would you share that code plug please?
we have the same issue in trying to reprogram a radius M1225. would you please share the code plug with us.
Kazzeki
Upon seeing no one minds if I put it out publicly, here's the codeplug file. please remember extracting it from the .zip
I've been reported that you may need to change the serial number before cloning. I don't know if they referred to either their radio or the codeplug, and how you manage to do that is beyond my knowledge. I'd try cloning it without any modifications first and see if it works.
Hope this helps.
  • 1225 codeplug.zip
Kazzeki
Do be warned, this is a GR1225 Codeplug meant for the GR1225 VHF Repeater unit.
